Check engine light code help
Old Sep 26, 2011 | 06:44 PM
Prototype's Avatar
Prototype
Default Check engine light code help
My CEL has come on a few times recently. Codes were 32 and 51. I found a list explaining them but am confused how to correct. The 32 refers to the EGR if the list I found is right. And 51 means the engine is running lean amd that thr computer tried to compensate to its richest setting but it didnt work. Im really not a mechanic, I usually work on PCs. If anyone is kind enough to help I would appreciate it. Sorry for any spelling errors Im on my phone
Old Sep 26, 2011 | 09:13 PM
Need to find out why it's running lean first...... (not getting enough gas) Might be low fuel pressure, or, it might be a bad O2 sensor. If the O2 sensor is original, it's past time for a new one...... That might solve the egr issue as well.
Old Oct 18, 2011 | 05:48 AM
Prototype's Avatar
Prototype
I know I'm late getting back to this but a close family friend recently passed and I've been distracted. Anyways, seeing how RockAuto had the EGR and O2 for a total of $62 shipped whereas Autozone wanted that just for a new O2 sensor. I bought them both. I don't know if the actual EGR valve was bad but the transducer thingamabob was toast.. Here's a few pictures of it. Replacing that thingamabob seems to have stopped it from throwing the 32 code. At least for the time being. I still haven't got the the O2 but I presume that it will be in the same or worse shape. Primarily because it was a Canadian truck and all of the road salts and what not being exposed to it. Name:  f4794a77.jpg
Size:  117.9 KB Name:  98132309.jpg
Size:  88.3 KB Name:  eff7433a.jpg
Old Oct 18, 2011 | 09:06 AM
Wow, that's pretty tweaked..... Looks like it got melted.
Old Oct 18, 2011 | 02:35 PM
Wombat Ranger's Avatar
Wombat Ranger
I just replaced mine a week ago, it was so melted that the top and bottom were only held together by the spring inside. I stuck it between distributor wires to keep it off the block, since there's no real mount.
