New Injectors what kind of tune?
Old Sep 27, 2011 | 11:03 PM
weatherman929's Avatar
weatherman929
Originally Posted by Adobedude
No were saying if you run the 24s, you have to get it tuned or you are going to lose MPG and power....
Or just get some stock injectors, call it good and sell the 24s.
Thats probably what ill do because I originally ordred stock ones but they got lost in the mail and got sent these instead
Old Sep 28, 2011 | 12:17 AM
CPTAFW163's Avatar
CPTAFW163
WAIT,
I have the bosch 24# injectors. You can get a SCT tune from hemifever for 365 and he can give you what is pretty much my tune. And it would be for 87, 91 and 93 octane.
It would not be completely dialed in, but it will run A LOT better. Plus it leaves some room for upgrades if you decide to get new heads/cam.
However, if you can get the 19lb YELLOW TOP Bosch Design 3s, you would benefit from the 4 hole design:
http://fuelinjectorconnection.com/sh...d&productId=81
Only 169 from Fuel Injector Connection.
19 lb.hr might sound low, but they are rated at 45 PSI. So they will flow around 20.5.
Those Bosch 24s you have, are flowing at 25.5 lb/hr.
I would try to see if you can get the Bosch Design III (4 hole) injectors rated at 19 lbs/hr.
--Dan
Old Sep 28, 2011 | 09:36 PM
weatherman929
Originally Posted by CPTAFW163
WAIT,
--Dan
NVM i do have the 4 hole injectors (the blue ones with the 4 holes)
Old Sep 28, 2011 | 11:50 PM
CPTAFW163's Avatar
CPTAFW163
ah, you are gonna be running REALLY rich BLUE= 24lb/hr but it ends up being 25.5 lb/hr at 49 PSI. The yellow ones are 19 lb/hr that will flow about 20-21.
PM hemifever and say you have bosch 24# injectors. He can pick a fuel curve for that without a wideband reading from your truck and get you working better. It will cost 365 dollars.
Or you can return those blues for the yellow ones.
I would get the yellow ones.
