lean when cold
Old Sep 28, 2011 | 11:25 AM
rollingdodge's Avatar
rollingdodge
Default lean when cold
I have a ram1500 with a v8 5.9l and i just put heads and did the kegger mod. I have been trying to figure this out but cant. When i first start it up(when the engine is cold) it idles way lean and will continue when driving. But it i stab the throttle wot for just a second from then on its good. Until it cools down again. What do you think would cause this? I have done tps sensor, temp. Sensor, intake manifold temp sensor. I dont know. Anything will help. Thanks
Old Sep 28, 2011 | 11:31 AM
Check Fuel pressure.
Old Sep 28, 2011 | 01:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Stock heads? Was the plenum gasket still good? Maybe should replace o2 sensor also. And I'm just curious to know, how you know it's lean?
Old Sep 28, 2011 | 01:28 PM
rollingdodge
Why would it only do that when its cold. And go away? Wouldnt it be all the time?
Old Sep 28, 2011 | 01:34 PM
rollingdodge
There heads with bigger intake valves. I didnt the hughes fix. Its not leaking now. I have a air/fuel ratio gauge that i use for custom tuning
Old Sep 28, 2011 | 01:37 PM
hydrashocker's Avatar
hydrashocker
Not a slow responce O2 sensor.
It could be the intake manifold temp sensor, check resistance. I posted up the values in this section, search under me in here. Also I agree, a pre-cat O2 sensor could cause this issue.
Old Sep 28, 2011 | 01:49 PM
rollingdodge
I have tried two different intake manifold temp sensors. So i would be shocked if that was it. Ill try new o2sensors
Old Sep 29, 2011 | 10:45 AM
rollingdodge
Well i tried the pre cat sensor. And that didnt do it. Anything else?
Old Sep 29, 2011 | 10:47 AM
zman17's Avatar
zman17
And your using a wideband o2 with the gauge?
Old Sep 29, 2011 | 12:11 PM
zman17's Avatar
zman17
Ok, I was just confirming. Have you checked the ECT also?
