Halo headlight problem
Old Sep 28, 2011 | 11:37 PM
Coryh4225's Avatar
Coryh4225
Default Halo headlight problem
Ok I purchased a used set of the halo head lights for my 2001 dodge ram pickup non-sport and installed them. Everything installed easy but I'm having problems with the high beams. First off I have the harness that goes from one plug to two lights ( high and low). When I have the high beam light bulbs plugged in my high beam indicator on the dash stays lit at all time and if I switch to high beam the lights get really dim. But when I unplug my high beam headlights the dash light works fine. The light bulbs for the high beams are 9005s if that makes any difference. I can't figure out how to upload my pictures to here from my phone but I did find this link and it will kinda give you some insight on what I have.
Btw I checked the wires and they appear to be wired correctly but maybe not. There are two black wires in the middle and a red wire on one side, and a blue one on the other on the main harness that plugs into the factory plug. Any help would be appreciated.
https://dodgeforum.com/forum/2nd-gen...need-help.html
Old Sep 28, 2011 | 11:56 PM
gdstock's Avatar
gdstock
Check each wire to bulb socket. The one that is common to both is the ground. Usually red is hot and black is gound - but two ground doesn't fit. The link you posted has good diagrams. I would recomend using relays as Jason mentioned. I just rebuilt an older RV, updating electical and electronics. I used relays for nearly everything to minimize overloading switches and improve contol capabilities. I would not use wire smaller that 14 gauge, and tend to use 12 ga.
