94 ram 1500 cam questions
Old Oct 2, 2011 | 01:48 AM
Nortzy's Avatar
Nortzy
Default 94 ram 1500 cam questions
I am wanting to cam my 318 I've decided on the extreme energy cam XE262H and I was wondering what else should I upgrade to run the cam?
Old Oct 2, 2011 | 01:59 AM
97tn4x4's Avatar
97tn4x4
You need a programmer but since you've got a 94 you have to get a new PCM that's flashed with tune. You'll also need valve springs and that fun stuff.
Old Oct 2, 2011 | 02:17 AM
gdstock's Avatar
gdstock
Has the plenum been fixed? Any money spent with blown gasket under there is possibly wasted, and performance enhancements will be offset.
Old Oct 2, 2011 | 09:49 AM
Intake will have to come off anyway for a cam swap..... But.....
That's a hydraulic flat tappet cam. Not really designed for use in the magnum engines, even though they seem to think so...... (you want a roller cam.)
Won't be computer friendly either. You will need a custom tune, which means sending your PCM out to be tuned. Not cheap.
