1995 ram idiot light question
Old Oct 5, 2011 | 09:24 AM
cutthroatxxx's Avatar
cutthroatxxx
Default 1995 ram idiot light question
I have a 95 4x4 with the 5.9 when I first start the truck the only lights that pop uo is the check engine,oil&air bag.Shouldnt more....&when I push od it will illuminate should it illuminate when on or off?thanks!
Old Oct 5, 2011 | 09:46 AM
O/D light illuminates when Off. Brake light in the dash should test as well as the seatbelt light.
Old Oct 5, 2011 | 09:53 AM
cutthroatxxx
Just tryd again&your correct the belt&brake light do come on&thank you SO MUCH!My dumd a#$ has been driving with the od on.I thought when it was lit up it was on.
Old Oct 5, 2011 | 11:00 AM
TheycallmeLaramie's Avatar
TheycallmeLaramie
Well, you came to the right place and asked the right question Good luck to you and your ram, were here to help.
Old Oct 5, 2011 | 02:08 PM
cutthroatxxx
Could constantly leaving it in od cause problems?
Old Oct 5, 2011 | 02:14 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
if you are towing, yes. othewise, no.
