Valve Noise???
Old Oct 12, 2011 | 07:40 PM
Adobedude's Avatar
Adobedude
Cam will require new valve springs & pushrods...Should use adj rockers with a cam or the push rods will have to be dead nuts on...Stiffer springs run the risk of snapping the two piece valves so you need new valves....etc etc etc...$$$
Is your exhaust manifold leaking..?
Old Oct 13, 2011 | 11:57 AM
sandman0_0's Avatar
sandman0_0
Before you start getting that weird on it, do one simple thing..... Change the oil. Put in some regular, average, every day, dino oil. NOT synthetic. drive it a couple days, see if it doesn't get quieter.
I already did that, That was the first thing I did, oil and filter. Is there a check valve in the oil system? This is the first Mopar I have had. I had a 01 Dodge 2500 with a CTD and never had to do any work on that except everyday maintenance. I have always worked on performance boat motors, Mostly BBC and a few SBC. So this V-10 is very foreign to me.
Old Oct 13, 2011 | 12:03 PM
sandman0_0's Avatar
sandman0_0
Exhaust is fine,
Old Oct 13, 2011 | 12:37 PM
sandman0_0's Avatar
sandman0_0
I was looking at a good set of lash adjusting lifters, I figure I will send the heads over to my machine shop and have them go over them, This is my first experience with the mopar, I have mostly worked on performance boat motors, Mostly BBC and a few SBC. This V-10 is all new to me.
Old Oct 13, 2011 | 03:10 PM
Hans_GZP's Avatar
Hans_GZP
There is a pressure relief valve that sits above the oil filter. I believe it's a 3/8" allen. You will want to remove that along with the valve and spring and make sure no sludge is built up in it. If it has a blockage, it will keep oil from flowing to the heads.
Old Oct 14, 2011 | 12:57 AM
sandman0_0's Avatar
sandman0_0
Thanks, I will dig into that tomorrow.
Old Oct 17, 2011 | 03:40 PM
sandman0_0's Avatar
sandman0_0
I did the oil change, and I think it may have quieted it down a bit at low RPM. But it did not help at all at highway speeds. It is very loud above 55 with a light load on the motor. Do you guys think it is the lifters? What else could it be?
