Knocking front axle, joint
Old Oct 10, 2011 | 01:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by calumetbud
I think this repair is getting bigger than me..may have to call the pros..LOL Thanks guys
You already have contacted the pros! Only question left, is where do you live?
Old Oct 10, 2011 | 01:58 PM
merc225hp's Avatar
merc225hp
Is there any diff oil leaking out the diff tube at this time? I think I would fix the u joint, top of the diff oil and see what happens before I change the seal.
Old Oct 10, 2011 | 02:02 PM
stewie01's Avatar
stewie01
It's time's like these I'm grateful I only have 2 wheel drive
Old Oct 10, 2011 | 02:16 PM
calumetbud's Avatar
calumetbud
no oil in the tube.....And your right the pros are here....
Old Oct 10, 2011 | 02:26 PM
zman17's Avatar
zman17
So what part of the globe do you live? I for one like helping out DF members that live nearby.
Old Oct 10, 2011 | 02:41 PM
stewie01's Avatar
stewie01
I'm gonna have to move to New Hampshire
But seriously, it's not often you find people like zman willing to help out others like that. But I'm sure there are others like him in this forum!
Old Oct 10, 2011 | 03:07 PM
zman17's Avatar
zman17
.... my point exactly. I'm not sure how many others have the tool to install the seals though.
Old Oct 10, 2011 | 04:54 PM
calumetbud's Avatar
calumetbud
Blytheville,Ar is where I live
Old Oct 10, 2011 | 05:17 PM
zman17's Avatar
zman17
Damn, another one too far away.
Old Oct 10, 2011 | 05:29 PM
dhvaughan's Avatar
dhvaughan
back to the original problem...
when things are as they should be, the axle should be suspended in the center of the tube, and should never strike the tube.
so - either the u-joint is very very bad, allowing the wheel/hub end to flop around and strike the tube -
or - the axle is broken inside the tube, and flopping around in mid-tube
or - (drivers side, correct?) the side gear or carrier bearing inside the diff has something terrible wrong with it. unlikely.
check where your play is. is it at the hub/u-joint? or is the axle loose down in the tube? if down in the tube, you have a broken axle - and. for a temp repair, you could remove the inner half of the axle.
