im at a total loss.
"when i give it gass goes up to 2000 then drops to 200 within a split second".
That sounds like a throttle position sensor problem, although it would be doing it all the time, not just on hills, which seem to be your nemesis. The only thing hill-related I can think of are engine to chassis ground connections, that might be shifting when the body moves. Check all those grounds carefully.
"forget to mention lol also the bolt size is 1/2 inch"
Sounds like someone replaced the stock bolts (that have the 1/4" allen bolt heads) with regular 5/16" bolts with hex heads.
Hey guys, drop the tech stuff for a minute, and PLEASE READ THIS THREAD, https://dodgeforum.com/forum/2nd-gen...e-tragedy.html
