Please help
What side were you looking at for the valves. Driver or passenger?
Ok, there goes that theory.
Once you find TDC, and the second valve is closed, you need to make sure the pulley and harmonic balancer are lined up with the TDC on the timing cover.
If you have been rotating the engine crank to do that, THEN you will be negating all your TDC work. You need to reinstall the dampener/pulley in that position.
After that, all you need to do is line up both dots at 12 oclock and 12 oclock.
WAIT WAIT WAIT.
you don;t need to rotate ANYTHING after you get to TDC because the crank and cam are already lined up. You just need to reinstall the crank and cam sprokets 12 oclock and 12 oclock. THEN make sure the pulley/dampener is INSTALLED at TDC on the timing cover.
If you ahve not pulled the dist, then you don;t need to degree the camshaft or rotate it.
If you rotated the camshaft once you got the crank to TDC, then you will be on a wild goosechase
oh okay so basicly wen the vavles are closed thats TDC. now when i put the balcener on and align it to the TC cover then it will be trueTDC and the valves will still remain closed but the piston will have moved up the extra 1/8th of a inch to meet the TC mark?
SOLUTION:
1. Get engine to TDC WITH THE TIMING CHAIN ON, seems like you did that.
2. Take off the sprokets and reinstall them 12 oclock and 12 oclock
3. Install the timing cover and make sure the crank pulley/dampener is lined up with TDC.
4. Put everything else on and fire it up.
