Please help
Old Oct 12, 2011 | 11:57 AM
71dodge's Avatar
71dodge
Exclamation Please help
I cant get my truck started it just sits and cranks over what did i do wrong please help it is leaking fuel out of the bleeder. What did i do wrong??
71dodge's Avatar
71dodge
and it sounds like there is no compression when i crank it over it just sits there and cranks please help
Old Oct 12, 2011 | 12:04 PM
You just did the plenum fix, right? What else did you do?
Old Oct 12, 2011 | 12:05 PM
71dodge's Avatar
71dodge
i did the timing chain and a water pump to. i dont see what i could of done wrong?? will the truck run without water it or attempt to start ?? i also didnt bleed the fuel rails yet? but why would that make it sound like theres no compression
Old Oct 12, 2011 | 12:15 PM
71dodge's Avatar
71dodge
what did i do wrong
Old Oct 12, 2011 | 12:27 PM
71dodge's Avatar
71dodge
come on anybody? i need to know how to fix it.. and would the timing throw it off? i had it top dead center is that wrong
Old Oct 12, 2011 | 12:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You moved the cam and or crank after removing the gears?
Old Oct 12, 2011 | 12:33 PM
71dodge's Avatar
71dodge
yea.... i tried to top dead center it. what i did was get the harmonic balencer top dead with the case then pulled it off and slid the timing chain on
Old Oct 12, 2011 | 12:34 PM
zman17's Avatar
zman17
TDC is with both dots at 12 oclock. Or did you put them together?
Old Oct 12, 2011 | 12:35 PM
71dodge's Avatar
71dodge
mother F**KER!!!!! they wernt lined up thats why it isnt starting zman your the best. now i have to go tear this whoel F**k apart again
