4WD Problems, Go Figure!
Old Oct 14, 2011 | 05:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Try replacing the vacuum switch on top of the TC first.
Old Oct 15, 2011 | 06:23 PM
w.lawhorn's Avatar
w.lawhorn
Thanks guys, I have been toying with the idea of replacing the switch even though it seems to function correctly but its less than $20 so Im gonna give that a shot first. If not I'll just have to pawn my shotgun and buy a posilock kit. I have to have 4wd.
Old Nov 4, 2011 | 06:57 PM
w.lawhorn's Avatar
w.lawhorn
Ok, I changed the t-case vacuum switch. I had to use 4wd before I replaced it so I pulled the outboard hose like normal. I was driving down the road at 20 or so and the 4wd light went out. I couldn't get it to go back in so I replaced the switch and in 2wdthe outboard port pulls 15 as well as in 4wd. I guess the switch isn't being actuated now? Please help me im an ASE tech working on a farm because there are no jobs right now. I need my truck to be working. I can't afford a new tcase so it may be time for new wheels.
Old Nov 4, 2011 | 07:12 PM
dhvaughan's Avatar
dhvaughan
someone was asking for a temporary permanent lock the other day and zman came up with the idea of a split rubber hose with some hose clamps to lock the collar in the engaged position. i'd either just do that, or cobble up something like the perma-lock part number 1100
http://www.4x4posi-lok.com/app_dodge.html
if you do spring for the posilok, you and 5 other people can still get it here for $163 with free shipping and no tax.
http://www.amazon.com/4x4-Posi-Lok-P...0448623&sr=8-1
if they sell out, here it is for $165
http://www.shopjeepparts.com/posilok...02-p-9493.html
Old Nov 4, 2011 | 07:32 PM
zman17's Avatar
zman17
Both lines pull 15 at the same time? Or does the vac change when in or out of 4wd or 2wd?
Old Nov 4, 2011 | 07:33 PM
w.lawhorn's Avatar
w.lawhorn
It doesn't change always pulls 15 on outboard. New switch.
Old Nov 4, 2011 | 07:37 PM
w.lawhorn's Avatar
w.lawhorn
I can't have full time my front driveshaft already needs to be rebuilt. My mpgs kill me already I couldn't imagine all time 4wd.
Old Nov 4, 2011 | 08:14 PM
dhvaughan's Avatar
dhvaughan
it wouldn't be full time 4wd. it would be full time axle lock, which would turn your front drive shaft, but it would free wheel within the t-case.
most 4wd chevy trucks in the 70's, 80's were setup like this. it might cost you 1 mpg in drag because it turns the front diff.
Old Nov 4, 2011 | 08:19 PM
w.lawhorn's Avatar
w.lawhorn
Ok. I wonder though, if the part in the t-case that activates the switch is broke, is something else really f****d up in there?
Old Nov 4, 2011 | 09:26 PM
zman17's Avatar
zman17
You are right, the internal part that activates and deactivates the switch is faulty.
