Plenum gasket replaced?
Old Jul 25, 2005 | 11:21 PM
Dodge4x4810's Avatar
Dodge4x4810
Default Plenum gasket replaced?
I just bought my '99 ram QC 4x4 about 3 weeks ago, still warranty. I had to bring it back to the dealer to get the plenum gasket replaced. I have a hard time trusting used car dealerships. So when i go to pick it up, what should i look for under the hood? To be replaced it needs new botls right? And, should i change the oil to make sure the didn't put any additive in it to make it not smoke?
Thanks
Old Jul 26, 2005 | 05:11 PM
DODGERAM99's Avatar
DODGERAM99
Default RE: Plenum gasket replaced?
how much did the dealer charge you do change the gaskets?
to my knowledge I don't think the need new bolts, but the are will be clean because they have to use cleaner on the throttle body.
Old Jul 26, 2005 | 07:00 PM
steve05ram360's Avatar
steve05ram360
yes, you will need new bolts top and bottom... the intake manifold bolts and the plenum plate bolts are not re-useable. You can check to see if it's been replaced by lookin down the throttle body at the bottom of the intake manifold. there's a pic of the plenum in the DIY forum that you can use for reference. the swap is easy, just time consuming...
