47RE trans question
Old Oct 15, 2011 | 11:05 PM
V10_Ram's Avatar
V10_Ram
Default 47RE trans question
hi im rebuilding a 47RE for a 96 2500. for some reason the input shaft has side play in it. im guessing this isnt normal. i cant seem to find whats causing it. Does anyone have any ideas.
Thanks
Old Oct 16, 2011 | 01:33 AM
gdstock's Avatar
gdstock
What stage of this are you in? Can you post pictures? Did you download service manual? It has a good section on trans rebuild. I printed it and put in plastic sheet protectors and kept it on bench during my rebuild.
If you have the oil pump bolted back in, did you change the front bushing?
Old Oct 16, 2011 | 09:58 PM
V10_Ram's Avatar
V10_Ram
im loading all the components into the case. i did bolt the seal pump but without the o ring so i could easily remove it if i had to. i didnt change the bushing but i believe i got one with the bushing kit and will try that. it dosent look that bad. i can try to get pics any specific area? and i did get a service manual.
Thanks
Old Oct 17, 2011 | 08:31 PM
V10_Ram's Avatar
V10_Ram
changed the bushing tonight, nothing different. any other ideas?
