Coolant Issue
Old Oct 16, 2011 | 02:01 PM
maloudin1984's Avatar
maloudin1984
Default Coolant Issue
Replaced the thermostat, thermostat housing and gasket. Filled the overflow reservoir and started the truck. Noticed water dripping immediately when i started the truck. Replaced the Water pump about 36000 miles ago.
Dodge Ram 1500
5.2 V8
237000 miles
Old Oct 16, 2011 | 02:49 PM
Where is the water dripping from? When you did the water pump, did you replace the bypass hose?
Old Oct 16, 2011 | 03:13 PM
Aerogauge's Avatar
Aerogauge
Could be the timing cover gasket behind the water pump, happend to me recently. Thought it was the water pump and turned out to be timing cover gasket
