Posi rear end? Tighten up steering? Holley Air filter install, PIcture of the truck
I think it would be a close call between doing the 14x3, and just putting a high quality air filter in the stock box...... I want to do cowl induction, and draw high pressure air off the base of the windshield..... (at least, it is on the highway....) I don't care for forward facing scoops on a truck that I go off-road with...... Don't want to give it the opportunity to funnel water directly into the engine.....
About stiffening up the steering on these trucks, there are a few people on this forum that have done the "rock solid ram steering fix" shich involves replacing a spring a some other small parts at the base of the steering column with a highly durable bushing.
http://www.pavementsucks.com/board/t...ng-Fix-Install
http://www.rocksolidramtrucksteering.com/
I ordered mine 2 weeks ago but have not recieved it yet.
Youw ill run WORSE unless you get a K&N or cloth HpR (Spectre) filter. The paper filter will choke that engine.
This is the "best" filter in terms of cost (25 bucks), getting air in (MPG and power gain), but it lets lots of dirt by (Foam element):
Edelbrock pro Flo:
http://www.summitracing.com/parts/EDL-1002/
Edelbrock pro Flo:
Edelbrock pro Flo:
Edelbrock pro Flo:
I noticed a bit of throttle response increase when I put the new one on. And it is not even like my old paper was that dirty either.
You can also leave off the intake tube from the fender and it makes the sucking noise like the 14x3 and increases the response a little more.
