And another plenum ? read first then freak
Old Oct 29, 2011 | 06:59 AM
  #21
Novarider's Avatar
Novarider
Originally Posted by 71dodge
heres a BIG hint. DO NOT CHANGE YOUR TIMING CHAIN UNLESS YOU TDC THE MOTOR!!! i thought i was doing a quick plenum fix and timing chain. now i have to spend a extra 400 bucks for heads i shouldnt of needed
Didn't you move the cam after you removed the timing chain? That's what caused your problems not whether you set it to tdc or not
Old Oct 31, 2011 | 08:55 AM
  #22
71dodge's Avatar
71dodge
never took my cam out? i didnt TDc the motor and it threw the timing off. causing valves 2 smack pistons and pushrods to bend
Old Oct 31, 2011 | 09:05 AM
  #23
8uzzsaw's Avatar
8uzzsaw
I don't think you have to take the cam out to turn it.
