And another plenum ? read first then freak
Old Oct 18, 2011 | 10:53 PM
gdstock's Avatar
gdstock
Which is why he said to do it when shes NOT home.
Just make sure you're not gonna mess up the rack.
Y'all going to get his a** in trouble! Mom's can tell. ----- even if they are not home! That is covered in mom101 class!
Old Oct 18, 2011 | 10:59 PM
The happy home maker goon squad is going to come and tar and feather you now for giving out classified information. If your dog starts barking, you better start running.
Old Oct 18, 2011 | 11:13 PM
drewactual's Avatar
drewactual
Some whoopins are worth it... A clean intake manifold likely falls a bit short of that value though... Make sure she's gone for the afternoon before you pull the trigger on that..
Old Oct 18, 2011 | 11:17 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
This is why I stay here.
Old Oct 18, 2011 | 11:29 PM
J415's Avatar
J415
To the OP, what's the YMM or your rig?
Old Oct 18, 2011 | 11:50 PM
71dodge's Avatar
71dodge
heres a BIG hint. DO NOT CHANGE YOUR TIMING CHAIN UNLESS YOU TDC THE MOTOR!!! i thought i was doing a quick plenum fix and timing chain. now i have to spend a extra 400 bucks for heads i shouldnt of needed
Old Oct 18, 2011 | 11:54 PM
71dodge's Avatar
71dodge
oh and when you remove the intake you need new intake bolts. there TTY (torque to yeild) and you cant reuse them
Old Oct 28, 2011 | 11:54 PM
EFS463's Avatar
EFS463
71dodge I read your thread I dont want to get into a mess like that lol
Old Oct 29, 2011 | 02:32 AM
joekool4's Avatar
joekool4
I'm getting ready to do mine too, probably a manifold swap tho and maybe timing chain and efan. I also have to put in my new speed sensor and new balljoints. Luckily I have a bike to get to work, but i may just take a few nights off and take everything down to my mom's and use her garage and driveway (its bigger, empty 2 car vs my 1 car with my girl's camry in it), her dishwashers broken though. good luck, i would plan on getting up early or starting Sat night.
Old Oct 29, 2011 | 06:46 AM
redneck_ram's Avatar
redneck_ram
i did my timing chain water pump and plenum repair all at once and i never put my engine to top dead center. truck runs fine, and not a single problem with it other than some how getting something in my oil pan causing oil psi problems.
