94 1500 5.2 won't start
Old Oct 24, 2011 | 01:39 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by lewisc7
Not sure the brand of cranksensor I got it from autozone, luckily it's under warranty and going to try it this after noon when the new one arrives. Checked the fuel pressure it was touching the 40's with just the key on. I'm changing plugs when I pick up the sensor today. I'll let everyone know what happens.
If you still have the original sensor. Compare it to the new one like I said. And if you got it at Autozone, that means it's a Duracrap. You should get one from the dealer or at least a Standard Motor Products brand.
Old Oct 24, 2011 | 10:20 PM
lewisc7's Avatar
lewisc7
Well changed the sensor and plugs and not even a burp. If I could've got a little running I'd ran straight to the dealer and got a good one but not even that. It's going to the shop tomorrow when I get home. I'm gonna hate what it turns out to be.
Old Oct 25, 2011 | 06:46 AM
zman17's Avatar
zman17
Try unscrewing the pre cat o2 sensor and see if it starts. Before talking to shop.
Old Oct 29, 2011 | 11:42 AM
lewisc7's Avatar
lewisc7
Am going to try that today if I can get it loose. Shop wait is a week just to look at it. I checked electrical today the dark green organe wire from the ASD to coil has no power, I jumped it and still wouldn't start would be strange if it's the o2 sensor.
Old Oct 29, 2011 | 12:21 PM
zman17's Avatar
zman17
The reason I suggested unscrewing the 02 is, to eliminate a possible clogged cat.
Old Oct 29, 2011 | 01:54 PM
Keep in mind, the coil and injectors will only have power for about three seconds unless the PCM sees the engine turning.
Old Oct 31, 2011 | 06:34 AM
lewisc7's Avatar
lewisc7
I disconnected the o2 sensor still no go, I tried to remove it but it's really in there, the guy before used it mainly for mudding and on a farm so it has seen better days. I did drop it off at a shop yesterday to get looked at, it may very well be the clogged cat because it has a funny smell when trying to start, almost smells like starting fluid but not totally. I left a note and mentioned it to the mechanic. I was worried about the PCM as in they aren't very expensive (compaired to others) but nobody around here can check it and I don't think I could return it if it wasn't it, but we'll see what the mechanic finds out.
