Warming up your truck in the winter?
#51
I installed an temp gauge in my drain plug hole and i have one in the trans pan and I can switch between the two cuz I use one gauge.. the oil temp on my truck even after ten miles on my drive to work don't get over 100 unless its idling for about 5 minutes and will climb to about 140 and stay there and once I start moving again it'll drop under 100 again... im not sure if having the clutch fan stuck on is having the oil cool down or not but that's my two cents ... actually neither the trans or the oil reach over 100 this time of the year on a daily basis
#52
#53
Honestly, the oil barely lubricates when it's cold, and oil pressure does not equate to lubrication. Cold oil under high pressure is not effective, it is resisting flow, and it's actually the flow of the oil that lubricates the engine. Also, oil typically doesn't reach it's full operating temperature for about 20 minutes, whereas the coolant will reach that in about 5 while driving.
I typically 0W-30 or 5W-30 synthetics in cold weather just so that it's thinner on cold starts. It'll flow much sooner than a 10w conventional.
Really awesome article:
http://www.ferrarichat.com/forum/faq...tor_oil_basics
#54
#55
