Chain or Belt driven what is better?
Old Oct 23, 2011 | 10:10 AM
charlie1935's Avatar
charlie1935
Summit Racing has this.
Gear Drive, Single Idler, Under Cover Style, Mopar, Small Block LA/Hemi, Kit
Part Number: MIL-13600 More Detail …
Old Oct 23, 2011 | 10:16 AM
EndIsNear's Avatar
EndIsNear
Originally Posted by aim4squirrels
From what I've been told, a gear drive on our particular engine would not be a good idea. The distance from the cam to crank gear is too great for the gear drive to run reliably in the space provided. I think they did exist for the older LA engines, but I don't know how reliable they were.
btw, that angle or distance from the cam to crank is what also makes for reliable and longer stroker motor possibilities.
I believe they used gear drives on aluminum blocks. Which if I remember, is an R3 block?
Old Oct 23, 2011 | 11:43 AM
Adobedude's Avatar
Adobedude
R3 is a Cast Iron block.
Absolutely no reason to go to a gear drive, get a good double roller and call it good.
Old Oct 23, 2011 | 12:13 PM
John D in CT's Avatar
John D in CT
I just looked at those in my Summit catalog, and it says "NOTE: Will not work on computer-controlled vehicles with knock sensors". I that us they're talking about? Do we have knock sensors per se?
"Absolutely no reason to go to a gear drive, get a good double roller and call it good".
I disagree with the first part (quieter, a little more precise long-term), and totally agree with the second part.
Old Oct 23, 2011 | 12:26 PM
zman17's Avatar
zman17
Retired Moderator - RIP
No knock sensor.
Old Oct 23, 2011 | 01:15 PM
No knock sensor, gear drives are louder than belt, or chain.... (unless it is specifically designated as a "quiet" drive.... otherwise, that blower whine is present). They are indeed more accurate though, and don't suffer from stretch at all.....
Not sure if the cam/crank spacing is the same from LA to Magnum blocks though..... I know the lifter angle is different.... but, never really got down to any other nits on that topic.
Old Oct 23, 2011 | 01:26 PM
John D in CT
"gear drives are louder than belt, or chain.... "
I was thinking of my International 392, which has helical timing gears. For the (straight-cut) gears made for Dodge engines, you're absolutely correct.
This cracks me up - from the Summit catalog:
"Machined for that distinctive gear drive "noise" ".
Oh yeah, give me that good old "five-speed backing up at 30 MPH" sound for my V-8; just can't get enough of that sound.
Old Oct 23, 2011 | 09:27 PM
Adobedude's Avatar
Adobedude
Installing a gear drive is not a bolt on job, it's going to require machining the block...So figure 375 for the gear drive plus pulling the motor, taking it apart blaa blaa blaa...
Drop 120 for a timing chain and another 40 on a tensioner and spend the left over money on gas.
Old Oct 23, 2011 | 09:49 PM
John D in CT
Old Oct 23, 2011 | 10:40 PM
White 98 4x4's Avatar
White 98 4x4
I am going to put a double roller timing set up in my truck and was wondering what would be best one to get. sorry for being off topic.
