New brakes smoking?
Old Oct 23, 2011 | 12:14 PM
showtimeweber's Avatar
showtimeweber
Default New brakes smoking?
I just recently changed my brakes rotors and calipers and when I drive the truck yesterday the brakes smoked everytime I stopped. 98 ram 1500 5.9
Old Oct 23, 2011 | 12:40 PM
John D in CT's Avatar
John D in CT
"the brakes smoked everytime I stopped"
Have you tried putting them on the nicotine patch? (haw-haw)
I keep seeing this complaint over and over. Sometimes the cure is replacing the front brake hoses, sometimes guys just take the calipers off and put them back on and it goes away, sometimes the calipers aren't sliding smoothly in the bracket. Seems to happen so much that it makes me wonder if it's a design flaw.
Did you put in rebuilt calipers, or use the old ones? [Scratch that - "changed" = "changed"]. Were the pistons fully pushed in, and did the pads slide easily over the rotors, or did you have to force them on?
Lastly, I always use brake lubricant (just heavy white grease) where the calipers slide.
Old Oct 23, 2011 | 01:13 PM
Did you clean the anti-corrosion coating off the rotors before you put the brakes back together?
