oil pan leak
Old Oct 25, 2011 | 09:03 PM
Terribly's Avatar
Terribly
Thats the problem with almost ALL seals... Cheap! But the labor necessary to install sometimes means 6 hours ripping out a transmission on your back!!!!
Old Oct 26, 2011 | 12:09 PM
scrappy2686's Avatar
scrappy2686
thats what iw as afraid you guys might say but im kinda glad you did because looking at the pan this time after draining my oil (for the third time) i noticed some small rubber pieces so guess what im gonna start doing. Dropping my tranny, pulling off my flywheel and replacing my rear main seal. fun fun :/
Old Oct 26, 2011 | 12:15 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
What kind of pan gasket did you use? I ran into this issue, thinking it was the rear main when it was actually the pan gasket. The gasket I had was very, very soft, almost too rubbery. The replacement is of stiff construction, meaning it will hold its form instead of being a dangly mess. I dabbed some sealant in the corners of the rear of the pan where it curves and my leak was fixed.
Old Oct 26, 2011 | 02:13 PM
redneck_ram's Avatar
redneck_ram
you dont need to pull the transmission to replace the rear main seal. just dropp the pan, remove the rear cap and take it out.
for some pointers and a how to look HERE.
Old Oct 27, 2011 | 01:34 PM
scrappy2686
that seems a lot easier but my truck plans have come to a halt today due to the fact its about to rain and i don't want to be under the truck with everything pulled off and then it start a down pour. but i will let you guys know how the end result comes out and if my problem is fixed.
Old Oct 28, 2011 | 07:24 PM
scrappy2686
well everything is bolted back up and torqued to specs. i will let everyone know the end result in the morning but this shade tree mechanic is going to the bar, drinking a few cold ones and then going to be young and stupid. as far as my ram goes, she will be sleeping tonight so the RTV will fully set and will be cranked and driven in the morning.
