just ordered my plenum kit and a few misc odds and ends tonight
Old Oct 27, 2011 | 11:15 PM
biggreen2500's Avatar
biggreen2500
Default just ordered my plenum kit and a few misc odds and ends tonight
hey i just got done ordering a few things
hug7720 plenum repair kit
hug7700 magnum intake bolt kit
hug1839180 degree thermostat
hug23139 oxygen sensor
grand total 208.71 with shipping
once it get heres in about 4-5 days i'm gonna put it on my truck
is there any other things i should consider doing while i'm installing these items?
i did my cap and rotor wires and plugs about 6 months ago so i'm gonna hold off on them for now unless you guess think i need to re do them.
i just used mid grade stuff when i did the plugs and etc
Old Oct 27, 2011 | 11:49 PM
lastrights's Avatar
lastrights
Timing chain
Old Oct 28, 2011 | 12:00 AM
biggreen2500
timing chain? i heard they wear out about 160k miles i'm rolling at 162k too..
i totally forgot about that do they install pretty straight forward or?
Old Oct 28, 2011 | 06:59 AM
Novarider's Avatar
Novarider
Water pump since you take it off why not replace it now. Bypass hose, catalytic converter, I would change the plugs again because it has been burning oil.
Old Oct 28, 2011 | 10:52 AM
8uzzsaw's Avatar
8uzzsaw
As for the timing chain, see about getting a double roller set. Like the one below. And make sure that when you put the gears back on, you line them up correctly.
http://www.summitracing.com/parts/CL...e%7c5.9L%2f360
Edit: Just ordered that set from Performance Parts website. Better shipping rates for Canada. Only $75 after tax and shipping
Old Oct 28, 2011 | 11:08 AM
Archion's Avatar
Archion
Did you order a programmer to go with that 180deg t-stat?
Old Oct 28, 2011 | 11:29 AM
8uzzsaw's Avatar
8uzzsaw
Don't forget to pick up all of your gaskets. Timing cover, exhaust manifolds, etc.
Old Oct 28, 2011 | 12:46 PM
biggreen2500
no i didn't ordering a programmer. i don't see why i'd need one right now.
as far as water pump goes and t chain. I'm gonna hold off on them after winter i'm gonna put a performance towing cam in from comp cams. and when i do that i'll replace the water pump and timing chain.
Old Oct 28, 2011 | 12:47 PM
biggreen2500
im guessing your live in canada aye? from jegs racing to my house is 9.99 i live here in the good ol usa
Old Oct 28, 2011 | 01:26 PM
8uzzsaw's Avatar
8uzzsaw
Yeah I live in Canada. It was $19.99 for shipping. Better than Summit. They wanted over $40 for shipping.
