Magnum Heads suck
Old Oct 29, 2011 | 03:28 PM
S S0DEN's Avatar
S S0DEN
Default Magnum Heads suck
Engine rebuild, sitting at machine shop and the heads are cracked between the intake and exhaust ports extending below the seats lol. No problem, I have another set of heads in the garage.... They are cracke too haha.
Time to pull away from the Mopar Cast Iron heads...
Old Oct 29, 2011 | 03:30 PM
Odessa, and Clearwater (basically the same company) make replacement heads that are better than stock (less prone to cracking....) for under 300 each. You can get 2.02 heads for under 500 a piece.
Old Oct 29, 2011 | 03:35 PM
S S0DEN's Avatar
S S0DEN
I will look into that, thanks. I was leaning to a set of a Edelbrock Aluminium heads...
Old Oct 29, 2011 | 03:37 PM
Them fellers are expensive.....
Old Oct 29, 2011 | 03:57 PM
J415's Avatar
J415
What cylinders where cracked? Just doing some info gathering.
Old Oct 29, 2011 | 03:59 PM
Adobedude's Avatar
Adobedude
www.IndyHeads.com
Overstock items...
Mopar aluminum Magnum heads
Bare. Was $950.00...Now $800.00
Assembled, 1.92 x 1.625, .525 lift springs, seats, moly retainers.
Was $1,250.00...Now $1,000.00
Not Eddies, but not a bad deal...lighter too.
