back together.
Old Nov 1, 2011 | 11:43 AM
71dodge's Avatar
71dodge
Default back together.
starting to put my truck back together. i set the timing marks just as the haynes manual said. cam gear at 6. crank at 12. ? i guess we will see today if it runs
Old Nov 1, 2011 | 12:17 PM
gdstock's Avatar
gdstock
As long as you did not turn the cam or crank by itself, it should run.
Old Nov 1, 2011 | 12:31 PM
71dodge's Avatar
71dodge
the cam and crank were turned by themselves. thats half the problem i had. but i took the heads off went i bent the valves TDC the #1 piston. put the cam gear on rotated the cam to 6 oclock. set the crank at 12. sliped the chain on and called it a day. it better be right because i set it according to the haynes manual
Old Nov 1, 2011 | 07:07 PM
BackwoodsRam's Avatar
BackwoodsRam
good luck man
Old Nov 1, 2011 | 09:19 PM
dlyter09's Avatar
dlyter09
Well any luck??
Old Nov 2, 2011 | 07:50 AM
Novarider's Avatar
Novarider
Did you make sure the cam is on the correct location? If #1 piston is at tdc both valves for #1 should be closed because that's the compression stroke right?
Old Nov 2, 2011 | 08:11 AM
71dodge's Avatar
71dodge
yea there right. i just spend alittle over 700 bucks on the top end now. it better be right
Old Nov 2, 2011 | 04:46 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You have to make sure the correct valve is open on #1. (Like in all the info you got in the other thread) You can't just turn the cam to 6 oclock position and call it a day.
Old Nov 2, 2011 | 08:53 PM
Novarider's Avatar
Novarider
Zman Shouldn't both valves be closed?
Old Nov 3, 2011 | 08:46 AM
71dodge's Avatar
71dodge
got the truck running had a few little problems with it (dodges half *** design on the water pump) but other then that it runs good. but now my brake light abs and engine light are on. im not sure why everything works fine. and shes running alittle hotter then usual (round 190) but im gonna save up and get the sct tune for it.
