Mopar Combustion Chamber Cleaner
Old Nov 2, 2011 | 05:07 PM
grox's Avatar
grox
Default Mopar Combustion Chamber Cleaner
I was reading the TSB for repairing the plenum, and at the end it instructs the technician to use Mopar Combustion Chamber Cleaner.
What do you guys think about this?
As a general rule I am opposed to buying fixes in a bottle and am also opposed to spraying things into my engine, so I'm skeptical.
Old Nov 2, 2011 | 05:28 PM
biggreen2500's Avatar
biggreen2500
well the cleaner would fix your leak... they probly put it in after they fix the plenum leak to help clean out the carbon and such from when it was leaking oil
the only true way to fix you plenum leaking is to repair the gasket and belly pan with a alum pan
Old Nov 2, 2011 | 05:38 PM
Silver_Dodge's Avatar
Silver_Dodge
It is a really good cleaner. I've used it for many applications on my engine. I recommend using it as described in the TSB.
Old Nov 2, 2011 | 05:40 PM
grox's Avatar
grox
Of course, the MCCC is to be used after the repair to remove carbon build-up from burning oil through the plenum leak.
biggreen2500
maybe i'll have to pick up a bottle off it and run it through after i replace my plenum this weekend
Old Nov 2, 2011 | 05:48 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1, Seafoam can also be used.
Old Nov 2, 2011 | 06:09 PM
biggreen2500
lol sorry i thought you were asking if that will fix it.. my bad buddy....
Old Nov 2, 2011 | 06:11 PM
biggreen2500
Talking
k i've seen seafoam all wal mart(my favorite hang out spot on Fridays lol jk)
and napa and o rileys and etc....
i've read the back of the can i've never bought tho
it says you can use it in diesels gas fuels, oils is it really passable that one product can treat gas, diesel fuel, motor oil and such?
Old Nov 2, 2011 | 07:42 PM
CPTAFW163's Avatar
CPTAFW163
Green,
Just pass the whole bottle through the vac line that goes from the brake booster into the intake. The RPMs will drop as you do this if you put too much in at one time.
Weird thing, when i do this to my wife's 2007 YUKON with the 5.3, the RPMs SKYROCKET enough for you to soil yourself. I think it is the PCM in the yukon due to the flex fuel tune. Seems when the engine boggs, it opens up the throttle automatically.
Old Nov 3, 2011 | 08:59 AM
charlie1935's Avatar
charlie1935
An old windex bottle with water will clear out carbon also. Cheaper too.
