fuel line on fuel rail help !!!!!!!!!!!!
Old Nov 6, 2011 | 02:35 AM
biggreen2500's Avatar
biggreen2500
Default fuel line on fuel rail help !!!!!!!!!!!!
hey i was watching this video on youtube.com and at 5mins and 38 sec into the clip it shows you need a speicel tool to remove the fuel line
his truck is a 96 and mine is a 01 do i share the same style fuel line or ?
http://www.youtube.com/watch?v=4lmX7lc1E64
Old Nov 6, 2011 | 03:36 AM
bwdakrt's Avatar
bwdakrt
Yelp. Same setup and uses the same tool for removal.
Old Nov 6, 2011 | 10:04 AM
Silver_Dodge's Avatar
Silver_Dodge
When I did my plenum, I tried to get mine disconnected, and could not. So I ended up just removing the injectors from the intake (pull straight up on them) leaving them still attached to the rail, then just zip tied the whole thing out of the way so I could remove the plenum. if you do it this way, you will want to replace the o-rings on the injectors, but honestly it was very easy and I didn't have to mess with that disconnect on the fuel line.
If you decide to do the fuel line though, make sure you depressurize the system first.
