i found a random wiring harness under the hood thats not connected
The one that has the pto label on it stands for power take off ... idk how to activate it or anything personally but the trucks we use that pto wire to energized a relay for an electric hydraulic pump ... and the harness on the passenger wheel well I was told by a stealership that ut was for something for the front axle for a light activation thing in which my truck is only 2wd so its just a standard wiring harness
The wire yellow wire under the dash is a jumper wire that is used on an automatic truck. On a manual truck there will be a netural safety switch in it's place.
I have a very simple DIY engine kill switch writeup on some other forums using that yellow wire. I'll post it up in the DIY section here and maybe someone can use the info.
Does anyone else have any input on this plug? Does it seem to be for the ABS???
The white plug on the pass side? I always thought that was the Air filter monitor for a diesel equipped truck. It's right by where the filter would mount....thats what those dimples under the air filter duct tube are for.
[/IMG]
