backlash and bearing pre load
Old Nov 13, 2011 | 12:56 AM
95BIGRED's Avatar
95BIGRED
Default backlash and bearing pre load
doing a gear swap in the front need to know the backlash and pre load for the dana 44.
Old Nov 13, 2011 | 07:02 AM
newman1367's Avatar
newman1367
Carrier bearing preload will be tricky. Before you pull the differential measure the rotational torque and keep it the same or a little bit more. Backlash is .005 to .008.
Old Nov 13, 2011 | 07:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
IIRC the entire procedure is in the FSM.
