Raptor 150 install wiring question
Old Nov 13, 2011 | 04:40 PM
tswan's Avatar
tswan
Default Raptor 150 install wiring question
So I got the raptor 150 w/ drawstraw and 1/2 line all the way to the injector pump.
It was an easy install except when it comes to the wiring, the instructions say connect the raptor ECM lead to the ECM pump lead. How do I identify this wire?
I don't follow this part. I turned the key on and found no power in the two wire lead that is behind the filter housing, does the key need to be in the start position to see power to the stock pump?
Thanks
__________________
2002, 2500, 4x4, automatic ,super chips, 4" exhaust, gauges,K&N filter,
Old Nov 13, 2011 | 05:10 PM
Power to the pump relay comes from ECM, connector 125, pin 8. (this is the control circuit power feed to the relay. circuit is grounded elsewhere, power feed is what turns it on/off.)
Power TO the fuel injection pump comes from pin 87 on the relay, Red wire, with light green trace.
Old Nov 14, 2011 | 02:51 PM
tswan's Avatar
tswan
Default raptor 150
Thanks for all the help, got it going.
Just key to on position gives 12v for 1/2 second, bump the starter and you get 12v for 30 sec.
I was Leary of bumping the starter w/ all the fuel drained from the system, but thats what it took, just keep doin that till you get fuel to the inj. pump.
Thanks again,
T
