Joys of a New Truck..
Old Nov 14, 2011 | 02:06 PM
jdh0921's Avatar
jdh0921
Default Joys of a New Truck..
Doing some work on the truck.. noticed a pretty solid leak in the power steering pump. The leak is coming from the shaft that connects to the pulley, and since I'll have to take everything off to fix the shaft, I may as well replace the pump since I'm there.
My questions for the forum is..
1. Can a leaky pump lead a symptom of "clunking" when turning.. it only happens when the truck turns one direction on a slope, so its not consistent.
2. Is there anything else I should replace as a maintenance item while I have the pump off, such as the return lines or anything like that?
Old Nov 14, 2011 | 03:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
For the clunking, check the end of the steering column where it exits the firewall. There should be no play. And also the lower front shock bolts may be loose.
Old Nov 14, 2011 | 10:21 PM
gdstock's Avatar
gdstock
Replace pump. Be careful pulling the pulley and do not beat the pulley onto nes pump shaft.
For the column issue mentioned by zman, http://rocksolidramtrucksteering.com/
