99 Dodge Ram running problem
Old Nov 14, 2011 | 03:56 PM
Nightryno's Avatar
Nightryno
Default 99 Dodge Ram running problem
I have a couple of problems I am looking for some guidance on. I have a 99 Dodge Ram 1500. It will start and when I start to drive and take my foot off of the gas it will die. It has a check engine light on that says the TPS is the problem. I have replaced the sensor twice. I have cleaned all of the grounds that I have been able to find. I also swapped out the computer. It is still showing that the TPS is the problem in the check engine light and is still dying. Also, I noticed that my passenger side headlight is good and bright but the driver side headlight is on but extremely dim. Can anybody provide some guidance on this? I am not sure as to the next steps that I should take. Thank you.
Old Nov 30, 2011 | 11:23 PM
socket462's Avatar
socket462
Have you tried cleaning the TB? The venturi that allow the AIS (auto idle speed) motor to work properly could be dirty and need cleaning. The headlight issue- have you swapped bulbs right to left to see if the problem moves as you move the bulbs?
