Starting all over again....new rig PICS.....
yeah its totally diffent than the 2wd... the 2wd was quick for a truck but i had every bolt on. This one will stay mainly stock motor wise just more along the lines of functional with this one i want a winch bumper and new lights and a good coat of paint and she will be done other than maybe locker up front and looseing the maroon interior going to get a set of iroks next 38's should clear
Ok, I concur with the color scheme. Great deal on the ride. Tires appear to have some good life left in them. PHAT Angry Pumpkin seems quite fitting. I'd agree that you can fit 38" no problem.
Request 1 - Can you reduce the size of the picture used in your signature?
Request 2 - Could you get a picture of the inner fender well where it appears that it was cut? I'd like to see how that was done. Unless that is just black paint...
Thanks!
Edit: stock axles?
Thanks!
Edit: stock axles?
Thanks!
Edit: stock axles?
Thanks!
Edit: stock axles?
They are cut the boggers that he used to have on there were 39.5 and they rubbed under turning and bumps i would assume cause they are so wide. I think he said they were 15 inches.
yeah stock axles. 4.88 gears and a arb out back. will prolly upgrade to 3/4 ton running gear when that problem arises
yeah i resized my pic once its still to big ....will take pics of fenders when i leave work. They are cut the boggers rubbed under turning and bumps i would assume cause they are so wide. yeah stock axles. 4.88 gears and a arb out back. will prolly upgrade to 3/4 ton running gear when that problem arises
And all this time I thought we finally got rid of you! LOL JK Nice truck
