Need some advice here plz !
Old Nov 16, 2011 | 05:33 PM
Drickp959's Avatar
Drickp959
New Member
Default Need some advice here plz !
i need a answer to this question !!!
I have a 1994 dodge ram 2500 4x4 5.9 gas.
early on in the week i went out to test the 4WD it did quite fine every thing engauged and work properly a couple days went by and i desided to to do a tune up on it so i got new plugs wires and distributor cap and rotor. then after the tune up i took it out to desert and found some mud ... went through got stuck and when i went for the 4WD nothing engauged exsept the transfer case
my question is is there any thing in the back of the block that could of got knocked off that has any thing to do with front axle/4X4 plus there is no vacumme pressure to the shift motor??? plz i need answers
Old Nov 19, 2011 | 12:47 AM
master tech's Avatar
master tech
Site Moderator & Tech
I will move your post to the ram section, this way you will get some answers.
Old Nov 19, 2011 | 06:28 AM
zman17's Avatar
zman17
Retired Moderator - RIP
http://www.dodgeram.org/tech/repair/..._engagment.htm
