Coolant Leak! Help please!
Old Nov 18, 2011 | 02:45 AM
DogeRamGuy1993's Avatar
DogeRamGuy1993
Default Coolant Leak! Help please!
Okay so i have a coolant leak! i have found where it might be coming from? it looks like its dripping right next to the rear main/oil pan. any ideas? maybe its coming from the heads?
thanks
Old Nov 18, 2011 | 06:05 AM
Josheis's Avatar
Josheis
Maybe freeze plugs?
Old Nov 18, 2011 | 06:06 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Most likely the freeze plugs on back of motor, sucks because you have to pull the tranny to replace them.
Old Nov 18, 2011 | 08:01 AM
Sheriff420's Avatar
Sheriff420
Any pictures?
I set my camera on the close up setting and started snapping pictures from all over the engine. My coolant leak ended up running down the oil pan next to the bolts then down driver support strut that goes between the engine and the transmission. The pictures showed me that it originated at the timing cover.
