4X4 went out, cad issue, diaphram, posiloc?
Old Nov 20, 2011 | 01:03 AM
NCC74656's Avatar
NCC74656
Smile 4X4 went out, cad issue, diaphram, posiloc?
My 4X4 went out and upon dissasembly of the CAD i found the fork was unable to move all the way across the shaft. the vacuum lines work so i hammered on the fork to force it over however i only got it about 1/4 of the way. i ordered the posiloc cable system to bypass the vacuum system and it came in the mail yesterday. i plan to install it tomorrow but i wanted to know if anyone has any thoughts on issues i may run into tomorrow.
on a side note, looking forward to using my first set of air tools i picked up last week :P
Old Nov 20, 2011 | 01:36 AM
gdstock's Avatar
gdstock
Air tools good...More power!
There are several good DIY threads on CAD here. I have read quite a few of them, but do not know anything first hand as I have a 2wd. SOmeone that has experience on this should post up soon (zman) if they have not all logged off and hit the rack for tonight!
Old Nov 20, 2011 | 02:04 AM
NCC74656's Avatar
NCC74656
yes, i agree. bigger is better. i got a 25gal air compressor dual piston that goes to 200psi for 30 bucks off craigs list. it was made in 1968 wich makes it much older than I.
i got a full set of impact sockets standard and metric for 100.00 and an air grinder/impact gun for 25 each. all snap-on
Old Nov 20, 2011 | 07:31 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Make sure you plug the white or grey vac supply line going down the back of the motor. And when you remove the CAD, make sure the collar slides back and forth easily. If not, there may be burs on one or both of the shafts. There is also a composite bushing between the two shafts, make sure it's not loose.
Old Nov 20, 2011 | 11:01 AM
NCC74656's Avatar
NCC74656
thank you zman, when i checked it 2 weeks ago the collar slid perfectly smooth, there was a small chip our two out of the edge of the inboard shaft but aside from that it all looked good.
Old Nov 20, 2011 | 11:31 AM
zman17's Avatar
zman17
Well those chips could be the cause of the whole problem. Depending on what position the outer shaft is in when shifting to 4x4. The Posi-Lok may have the same problem.
Old Nov 20, 2011 | 07:15 PM
NCC74656's Avatar
NCC74656
i can not move the shift fork manualy and the vacume lines do not make the fork move across the rail either. currently i am trying to remove the damn fork from its housing but i cant get the snap ring off on the side of the fork that faces the vacuum pump. the other 2 clips are off.
Old Nov 20, 2011 | 08:14 PM
dhvaughan's Avatar
dhvaughan
here's some thoughts... https://dodgeforum.com/forum/2nd-gen...installed.html
use care to tie the cable away from the exhaust manifold with numerous wire ties. mine slipped over onto it and melted the crap out of of the outer casing but it still works.
take your time with the placement of the hole through the firewall. there's a heavy steel plate around the column you want to avoid.
Old Nov 20, 2011 | 10:15 PM
NCC74656's Avatar
NCC74656
i just finished installing it. when if i dont push the knobb in and screw it a bit it detects my 4X4 as on (dash light) and when i do engage the 4X4 it works however if i lay on the gas i hear a very fast high pitched whine, sounds like teeth on teeth so i think perhaps the collar is not moving over far enough. i installed the after market plate with the wire running from passenger side to driver side and the fork is placed with its off set over hanging the wider part of the housing cover.
on a sad note i was unable to use my air tools as we do not have an outlet in teh house that can run my compressor. its 110V at 40A while the house only has 20A
Old Nov 20, 2011 | 10:26 PM
gdstock's Avatar
gdstock
If the motor is dual wound (multiple voltage) is can be swithced to 220 v and it will be 20A - if you have 22v 20A available in the house.
