2000 Ram 1500 5.9 4x4 spark plug issue
Old Nov 20, 2011 | 08:52 AM
zcrashz's Avatar
zcrashz
Default 2000 Ram 1500 5.9 4x4 spark plug issue
I am trying to change out my plugs, the truck died on me the other day.. I replaced Cap and pulled the wires off and cleaned all the dirt and junk down inside the heat shields, turned the key and it fired for about a minute then died again, waited a few and did it again fired for a min but i had to keep foot on gas as soon as i took foot off it died... so i want to change plugs and see if that helps... i got the two front plugs on driver side out, none of the others want to come out easily... to me it feels like the h/s is too tight towards the bottom and wont let the socket around the plug... is there a way to remove the h/s with the plugs still in... if not any suggestions how to get the plugs out they are pretty rusted and in tight... thanks for any help...
Old Nov 20, 2011 | 08:59 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Grab them with vise grips and wiggle around and pull. You might want to try this for the stalling though. https://dodgeforum.com/forum/dodge-r...n-the-iac.html and check inside your intake while your at it. Read this thread too https://dodgeforum.com/forum/2nd-gen...um-thread.html
