interesting blinker issue
Old Nov 20, 2011 | 01:27 PM
95BIGRED's Avatar
95BIGRED
Default interesting blinker issue
for the first five minutes of running both blinkers work fine. after the five minutes the right blinker wont work the front will come on solid but the rear will not come on as well as the break light. kinda confusing this occurred after i regrounded my stereo so i moved the ground and just took it out completely and still have the issue. thanks for your help in advance.
Old Nov 20, 2011 | 02:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The headlight switch might be heating up and your plug on the back is melting. Common problem.
Old Nov 20, 2011 | 02:35 PM
95BIGRED's Avatar
95BIGRED
well the headlight switch was replaced a few months ago. what causes it to heat up and how is it related to the blinkers?
Old Nov 20, 2011 | 02:57 PM
zman17's Avatar
zman17
Damn you ask a lot of questions, LOL The headlight switch and the mutlifuction switch are both wired in conjunction with each other. You should also remove the covers off the steering column and look for damaged wires if you have a tilt wheel. Also look for damage on the back of the multifunction switch plug.
Old Nov 20, 2011 | 03:01 PM
dlyter09's Avatar
dlyter09
I had an issue with the headlights a few weeks ago. Pull the column covers off and have a look at the plug directly behind the multifunction arm. Check all wires carefully to make sure they are all in tight and that none of them are lose in there causeing it to heat up/ or short out. Common problem on the tilt wheel for wires to get pulled out of that switch or get pinched in there.
Old Nov 20, 2011 | 04:08 PM
Jimythefan's Avatar
Jimythefan
My vote is flasher relay.
Sounds similar to a problem I just had and it was the flasher.
Old Nov 20, 2011 | 06:50 PM
95BIGRED's Avatar
95BIGRED
zman i ask alot of question because i want all the facts before i go into anything and end up making it more work for myself later on.
i just pulled off the column cover and i dont see any loose wires pinched wires or melted wires. would a faulty flasher only allow one side to work, and like i said up top the right rear blinker doesnt even come on, neither does the break light.
Old Nov 20, 2011 | 08:59 PM
95BIGRED's Avatar
95BIGRED
ok so i replace the flasher and the bulb, got her workin again. thanks for the help everyone.
Old Nov 20, 2011 | 09:03 PM
crazzywolfie's Avatar
crazzywolfie
so you weren't low on blinker fluid?
Old Nov 20, 2011 | 09:06 PM
gdstock's Avatar
gdstock
And I was thinking blinker filter....
