heat doesnt work
Old Nov 20, 2011 | 09:08 PM
sam_priem's Avatar
sam_priem
Default heat doesnt work
its gettin to be a bit cold old and my heater hasnt been working. i dont know what to do about it. i think its either the thermostat or heater core but i dont know how to check. any tips or other ideas?
Old Nov 20, 2011 | 09:27 PM
gdstock's Avatar
gdstock
Does engine get warm enough? What does gauge read after it has run for a while?
If stat is stuck open, the engine may not be heating up enough. If it is stuck closed, you would be overheating.
Have you recently changed coolant? If so, there could be air trapped in system. You need to have nose of truck raised and running and heater turned on, and make sure it is full so air bubble will flow out.
Check behind heater/ac controls to make sure everything is connected. If bypass door does not operate correctly, it cannot divert air through heater core.
Is the carpet on pass side getting wet or do you smell coolant from insde the cab? If so, this is a sign that core is bad.
Old Nov 20, 2011 | 09:54 PM
sam_priem's Avatar
sam_priem
it gets to 210 degrees and stays there which is what its supposed to be
no i havnt changes coolant recently
carpet doesnt get wet and i cant smell coolant in the cab
as for connections ill check those this weekend
Old Nov 20, 2011 | 10:01 PM
gdstock's Avatar
gdstock
So stat appears to be working, and heater core is not leaking, and it is probably not air trapped in system.
Hopefully you can find a connection loose. Also remove glove box and look at heater door behind there. Check for connections there also.
Do you have the service manual? If not, you can download from the FAQ/DIY section. Troubleshooting detailed pretty well in there for connections both vacuum and electrical.
