LED Tail lights
Old Nov 21, 2011 | 05:00 PM
1LoudSport's Avatar
1LoudSport
Default LED Tail lights
I want to get LED tail lights for my sport but not sure if they wiring is different. Also if anyone knew where to get them besides ebay? Thanks
Old Nov 21, 2011 | 05:12 PM
EndIsNear's Avatar
EndIsNear
http://www.andysautosport.com/dodge/...o00000124.html
Old Nov 21, 2011 | 06:06 PM
kejobe's Avatar
kejobe
http://www.lmctruck.com/icatalog/de/full.aspx?Page=67
Old Nov 21, 2011 | 10:51 PM
Pronk's Avatar
Pronk
Yeah you should be able to find tail lights on most aftermarket auto websites. I'm pretty sure the wiring is all the same, I don't see why it would be any different
Old Nov 22, 2011 | 12:14 AM
94ram4x4911's Avatar
94ram4x4911
I got the ones from lmc for mine, they just plug right in where the bulb goes and you re-use the reverse lights
Old Nov 22, 2011 | 01:01 AM
biggreen2500's Avatar
biggreen2500
u can get the same ones from LMC for way cheaper on ebay just a side note and yes the SPORTS have the same tail light wiring... as non sports
Old Nov 22, 2011 | 02:38 AM
beeker's Avatar
beeker
Don't you need to install a resistor to load the circuit to prevent hyper-flash? Or install a electronic flasher?
Old Nov 22, 2011 | 09:10 AM
wermbang's Avatar
wermbang
I had to add resistors to mine, but I just switched to LED bulbs. I always thought that the full led lights came with something built into them so that they are plug and play, but I may be wrong
Old Nov 22, 2011 | 11:32 AM
94ram4x4911
If you buy the full LED tail light they come with them built in
Old Nov 22, 2011 | 03:29 PM
biggreen2500
mine came with them attached to the tail lights my blinkers don't blinker fast
