got a new muffler put on a now a few days later my truck is loud and lacking power.
Old Nov 26, 2011 | 10:05 AM
Sheriff420's Avatar
Sheriff420
I say a clamp wasn't tight enough, the pipe slipped off and now the disconnected pipes are touching where it slipped off.
I can't stand those clamps because I can never get a good seal with them. Now that I have a welder I don't have to mess with them though.
Then again, my sisters truck had the rattle only for a few seconds after starting it when the cat was bad.
Old Nov 26, 2011 | 10:25 AM
lastrights's Avatar
lastrights
Beats having a cutout lol just undo the clamp
Old Nov 26, 2011 | 01:00 PM
2000ramsport's Avatar
2000ramsport
ok the muffler is the same muffler they took off it was the stock muffler that came from dodge thats what they put back on the same stock muffler that was there when it was new.and that white stuff i see is cement??? they used 2 clamps and cement then im going to go there today before they close .why did they use cement?i really dont know much about the reason for using cement so the more i know before i go there the better off ill be.the guy did tell me he was using some new machine to seperate the pipes to get the old muffler off not sure what he used though.can i hit the cat or not to see if its broke?some of you are saying do that and you are saying dont do it?
Old Nov 26, 2011 | 01:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The sealer just helps when using clamps .
If they used "cement" there might be a problem. LOL
Old Nov 26, 2011 | 01:57 PM
2000ramsport
ok i just found the problem the cement is where one clamp is and its lose.shouldnt a muffler shop do a weld and not use cement?im on my way up to the shop to see what they say should i tell them to weld it?thanks guys.
Old Nov 26, 2011 | 03:08 PM
4HoNdaDODGE's Avatar
4HoNdaDODGE
how much did you pay this shop?
Old Nov 26, 2011 | 03:47 PM
grox's Avatar
grox
If they didn't have to do any cutting or welding, it shouldn't be more than a one hour job for a basic technician. I hope they didn't charge anymore than $65 labor, and should probably be less than that if they want repeat business.
Old Nov 26, 2011 | 06:42 PM
4HoNdaDODGE
idk i have a feeling this guy probably paid a lot and didnt get a kiss when they were done hahahaha
Old Nov 27, 2011 | 12:04 AM
2000ramsport
It took them an hour the first time I got it welded back on the guy told me they dont like to weld it cause it makes it harder to get off when another muffler is needed cause it has to be cut off.The muffler that rusted off was not welded it was just held on by 2 clamps thats the way it was when I bought it.Anyway its welded back on took the guy an hour to do it.After they weld it on they tell me they dont like to weld mufflers on cause stuff going flying all over the place when you weld lol.I wont be going back to this shop again and the labor rates are $98 an hour the sign on the wall said most shops here where I live charge 75 to 95 an hour for some reason.Then he tells me the muffler came lose cause the metal expended I just told him to weld it back on they did it and its done. oh and the power is back now with the truck it was the lose muffler go figure.the loud sounds gone too and the rattle sound is gone it was all the muffler.grrrrr
Old Nov 27, 2011 | 09:49 AM
4HoNdaDODGE
so all together what did this run you? if you dont mind me asking hahah
