cracked heads?
Old Nov 26, 2011 | 08:59 PM
candymancan's Avatar
candymancan
You know with this cracked head issue poping up all the time i almost wonder how Chysler got away with this aparent major and costly defect..
Old Nov 27, 2011 | 09:02 AM
The heads generally lasted longer than the warranty...... and it isn't really a 'safety' issue, so the fed won't get involved.
If you are still having mystery coolant loss, I would take a sample and have it analyzed. Should be able to tell you if there are combustion byproducts in your coolant. (sign of blown gasket/cracked head)
Old Nov 27, 2011 | 12:45 PM
candymancan
na my coolant isnt going down anymore, i found where the coolant was coming from, the petcock was leaking very slowely not sure why as it was fairly new but i replaced it again and just going to keep an eye on it, that and it seems some coolant is leaking out of the overflow drain in the reservoir probably from sloshing around when i drive as i saw a few coolant drips from it the other day.
Pretty sure thats where the coolant is going
Old Nov 28, 2011 | 02:04 AM
4085spd's Avatar
4085spd
Install a 180 ASP so your heads wont crack from the excessive heat produced by the stock 195 and with a new rad you will be good for long time to come. FYI the cracking issue was bigger then the plenum issue and when these trucks were new Chryler couldnt keep cylinder heads in stock and at one point 97-98 they where on national back order. Took over three months to get mine replaced under warrenty.
Old Nov 28, 2011 | 09:55 AM
1&2genrams's Avatar
1&2genrams
I did put a 180 in before my "major meltdown" and a 2nd one thinking that was maybe the problem before I discovered the rad was to blame.....anyway I guess what my original question was ( I was aware of the head issue, just not all the causes or symptoms) has anyone had a similar experience with the same results.
I am definatly losing some coolant, and the missfire codes are for the 2 plugs that look suspect, so I am going to do a cooling system pressure test and a cylinder leakdown test......but I already think I will be pulling the heads....I will post my results
Old Nov 28, 2011 | 12:38 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I would just suggest you tackle each of those tests. Go step by step prior to making any conclusions. Deductions are great, but sometimes in thinking/perceiving is far reaching. Not in any way saying you're off base, just stick to the tests to become more confident of the end diagnosis.
Yes, please do report back. Pictures would help alot too.
Old Nov 28, 2011 | 01:17 PM
1&2genrams's Avatar
1&2genrams
Yes I definatly agree with you, each test will be done before I start tearing into it...and I will post my results of each test as they are done....along with pics !
Old Nov 28, 2011 | 02:21 PM
DodgeTheDadRamTheDaughter's Avatar
Originally Posted by S S0DEN
Magnum heads crack a lot, in my engine rebuild, I found both heads cracked between the exhaust and intake valves below the seat. I had an extra set of the same heads from the wifes Durango, they were also cracked in the same spot on all valves.
x3 on this one, My truck never overheated and just by random chance i had to take my heads off because my manifold studs broke off in the head. While they were off i had them checked and sure is crap the valve seats were cracked.
Old Nov 28, 2011 | 05:12 PM
candymancan
I dont see wha ta 180 tstat will do ? My Jeep 5.9 never goes above 195-200f eve in the summer i stayed at 200f. Altho i think with the electric fan vs your clutch fans i stay cooler then you guys do.
Old Nov 28, 2011 | 06:17 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
FYI is all just b/c its very recent.
https://dodgeforum.com/forum/2nd-gen...stat-help.html
