Best wheel offset for 35"?
Old Nov 26, 2011 | 10:14 PM
FireDodge's Avatar
FireDodge
My buddy has a 3500 diesel that he took off the dually's and put on a standard bed. He has 315's on his and he gets a very small rub at full lock and his is all stock suspension. He got a leveling kit for the front and it dern near fixed it.
Old Nov 27, 2011 | 02:50 AM
biggreen2500's Avatar
biggreen2500
i have these with 35x1250x20 there 20x9
http://www.discounttire.com/dtcs/whe...98225&pc=49118
i have no rubbing at all and i have a 01 dodge ram 2500 4x4 with a 2in level kit in front
Old Nov 27, 2011 | 11:40 AM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by CSCustomCars
Well, these tires are on my factory wheels now, and they are 7" wide iirc, but I could be wrong.
Either way, I may downsize my tires to a 305, but I still need a better offset.
Thanks heyyou for the info.
widest tire you can legally put on a 7" wide rim is 11.5" I believe...8" is the narrowest rim for a 12" wide tire...and that will make the tire seem thinner than it should ..as for backspacing ironically the factory backspacing on an *" wide rim cleared and had less rubbing issues than my rims Im using now which stick out more and give the truck a slightly wider looking stance..(I have 35" tires with a 3" body lift.)
There must be a steering ratio adjustment because I had no rubbing at full lock against anything but the body when on and angle and the spring (s) were partially compressed.
Old Nov 27, 2011 | 12:03 PM
CSCustomCars's Avatar
CSCustomCars
Thanks augie for the info.
