Best wheel offset for 35"?
Old Nov 26, 2011 | 12:57 PM
CSCustomCars's Avatar
CSCustomCars
Default Best wheel offset for 35"?
Whats the ideal wheel offset for 35" tires on a 2000 2500?
Or, what range should I shoot for? 4.5"? somewhere in there?
Inches would be helpful, but I can convert the mm if I need to.
Need to get some steering range back.
Thanks!
Old Nov 26, 2011 | 01:08 PM
How wide are the rims you want to run?
Old Nov 26, 2011 | 01:12 PM
CSCustomCars
found used ones, 7" wide. Not the best width, but for the price, I'll take it.
And the actual tire size is 315/75/16.
Old Nov 26, 2011 | 01:28 PM
mccart's Avatar
mccart
Minimum wheel width for that size is 8 inches
Old Nov 26, 2011 | 01:29 PM
Those wheels are a bit narrow for those tires..... think they want 8 inch or better.... it should work... after a fashion. 4" backspacing should be about right.
Old Nov 26, 2011 | 01:37 PM
CSCustomCars
Well, these tires are on my factory wheels now, and they are 7" wide iirc, but I could be wrong.
Either way, I may downsize my tires to a 305, but I still need a better offset.
Thanks heyyou for the info.
Old Nov 26, 2011 | 01:38 PM
Stock offset is 4.5 on the 7.5 rims. You getting some rubbing at full lock?
Old Nov 26, 2011 | 01:53 PM
CSCustomCars
Yeah I am.
Old Nov 26, 2011 | 01:56 PM
You can go for shallower offset, but, they may just make them rub the fender opening instead. I think there is also the possibility of adjusting the steering stops, so they don't rub, but, that increases your already large turning radius...... Yet a third option is different lower control arms, I think there is a company that makes some that are kinda 'doglegged', so you have more clearance at the fattest part of the tire.
Old Nov 26, 2011 | 02:05 PM
CSCustomCars
I don't think I'll have fender rub issue. It's a diesel 4x4. There's a good foot, foot and a half on height between the top of the tire and the fender. And on the sides of the tire, there's a good 4-6" between max tire width and fender/front bumper - rear fender.
Even if I were to get full compression of the spring, it looks like I'd have enough room still. But I'd never even see half compression on the spring. I don't off road all that much, and I bought the truck with the 35's on it.
At full lock I'm getting rub on the inside, um... sway bar area I think? I haven't looked close enough to tell exactly.
