I've got two issues here, main being the horn!
Old Nov 28, 2011 | 08:19 PM
Rebel99's Avatar
Rebel99
Originally Posted by BigBlue83
Howdo i check a relay? when i bought my truck my horn didnt work now my fog lights ive read on here it can be the pcm but id like to check my relays...
You could take one of the same relay from another slot and try it to see if it works.
Edit - My fog lights currently don't work either, though I'm not even sure how to turn them on, I just use my brights when needed. (Took the working relay from my fog lights to make my horn work properly).
Old Nov 28, 2011 | 08:44 PM
BigBlue83's Avatar
BigBlue83
when i first got my truck the horn didnt work BUT the fog lights did than magically one day i realized i had no fog lights dont know if they whent at seperate times or what... in my truck theres a *** to the left of the steering wheel if you pull it half way its fog lights all the way is both fog and head lights (when they were working)
Old Nov 29, 2011 | 01:57 AM
Rebel99's Avatar
Rebel99
Yea then my fog lights never worked. I've done that and gotten nothing from doing so, but you could try and replacing one. Like my old taillight issue, replacing one can make the other work because they hit the same relay and cause the other to stop working. so you could try switch the bulbs around, maybe clean the sockets too.
