Pulling set up?
Old Nov 29, 2011 | 04:23 PM
  #21
EvanBoothe123's Avatar
EvanBoothe123
Originally Posted by gdstock
Probably wouldn't hurt......but tell me you aren't running a stock tranny....please tell me....
Lol sorry to say but yes I am. That's why I made this thread, so tell me what I should do about that stock tranny.
Old Nov 29, 2011 | 04:59 PM
  #22
dlyter09's Avatar
dlyter09
http://www.transmissioncenter.net/dodge.htm
Nuff Said.
Old Nov 29, 2011 | 07:06 PM
  #23
Gerehead8's Avatar
Gerehead8
Only pull in manual low (1). In this gear the low/reverse band is applied so the overrunning clutch does not hold the power. Don't shift the truck, the full throttle and heavy load would destroy it. If you don't shift the 46RE should be able to hold the power of a stock 5.2L as long as it does not overheat.
How long are the pulls on average? A temp gauge is a must, and make sure to put it in the output line of the trans. That will give you the fastest update on trans temps. A large cooler might help but without airflow it won't do any good. Maybe big electric fans could make a difference. Try to leave the factory radiator cooler in place and run the auxillary one after it as water will pull the heat out of the oil faster than air and the coolant is circulating cooling the oil even with minimal airflow. A large transmission pan will increase the volume of coolant and increase the heat capacity of the fluid. Aluminum would be better than steel as cast aluminum pans dissipate heat faster than steel.
Old Nov 29, 2011 | 07:19 PM
  #24
EvanBoothe123
Best way to install a temp gauge, and where to buy it. Mostly how would I install it into the output line.
Old Nov 29, 2011 | 07:32 PM
  #25
dlyter09's Avatar
dlyter09
I agree.. Just shift into first gear and 4lo and you shouldnt have much of a problem. Get a tranny temp sensor installed and you should be golden along with some ladder bars and gears.
Old Nov 29, 2011 | 07:39 PM
  #26
Gerehead8's Avatar
Gerehead8
The electric senders are 1/8" npt. On your '97 there may be a port right in the output line of the transmission (forward line), my '94 had one.
If you use a mechanical gauge you can use a T-pipe fitting. Unthread the JIC fitting from the transmission, and adapt the T to the transmission. Then just attach the line to the other side of the T and install the gauge to this.
I usually get Autometer gauges from Summit Racing. If you are going cheap you can use a mechanical water temp gauge from a parts store.
I have a Autometer full sweep mechanical gauge in a '97 chevy 3500 and even though it is mechanical it responds very quickly to changing trans temps.
Old Nov 29, 2011 | 07:48 PM
  #27
EvanBoothe123
Okay thanks ill probably pick up one of those C2's from summit, i like the white face with the blue led light up.
Old Nov 29, 2011 | 07:52 PM
  #28
EvanBoothe123
Also, does anyone have a link for a set of gears I could buy? Not to expensive lol.
Old Nov 29, 2011 | 09:58 PM
  #29
EvanBoothe123
Lmao I actually just went to hooked up to my friend with a bigger lift than mine and bigger tires, he has a chevy with a 350 and I threw it in first and four low and hardly even hit the gas and i drug him along no problem, no hop nothing. 2 times in a row.
Old Nov 30, 2011 | 12:31 AM
  #30
Wh1t3NuKle's Avatar
Wh1t3NuKle
What a jerk beatin' up on the little kids.
