Pulling set up?
Old Nov 30, 2011 | 04:21 AM
  #31
dlyter09's Avatar
dlyter09
Originally Posted by EvanBoothe123
Lmao I actually just went to hooked up to my friend with a bigger lift than mine and bigger tires, he has a chevy with a 350 and I threw it in first and four low and hardly even hit the gas and i drug him along no problem, no hop nothing. 2 times in a row.
Sounds familiar.. Ive pulled a few Cheby 350's in my time... As for gears im not sure that your gonna find much for cheap.
Try:
http://www.ringpinion.com/
http://www.yukongear.com/
Ive got yukon gears in my truck. You could also just get a locker or posi and throw it in the truck with a stock gear which would be cheaper then re-gearing completely.. Try lockright, powertrax, auburn, detroit or eaton. Those are just a few that you could get a locker or limited slip.
Old Nov 30, 2011 | 07:02 PM
  #32
EvanBoothe123's Avatar
EvanBoothe123
I overfilled my antifreeze? It's all over my engine did it push the stuff out somehow?
Old Nov 30, 2011 | 07:21 PM
  #33
dipsherry's Avatar
dipsherry
get a derale deep pan it comes with a trans temp hookup and holds 5qts extra...i know some will say it doesnt work but i noticed a trans temp drop in my old truck vs a stock pan.
Old Nov 30, 2011 | 07:48 PM
  #34
DodgeTheDadRamTheDaughter's Avatar
if your talking truck tug o war it does nothing to show your trucks power. You can have a higher pull point, thus lifting the other trucks rear end=you win, hold your breaks off the line while they spin the tires then ease in to the throttle=you win...truck tug o war seems cool but is all in all pointless
Old Nov 30, 2011 | 07:50 PM
  #35
EvanBoothe123
Anyone know why there's antifreeze everywhere?
Old Nov 30, 2011 | 09:21 PM
  #36
dlyter09's Avatar
dlyter09
Maybe you have an issue like me and your water pump is leaking. Mines leaking pretty good and it drips onto the fan and gets shot all over the place.
Old Nov 30, 2011 | 10:08 PM
  #37
a-master's Avatar
a-master
Here ya are fine sir.
http://completeoffroad.com/c-69615-p...-packages.html
I bought the 4.88's from them. SPECIFY THICK CUT D44 GEARS.
Old Nov 30, 2011 | 10:16 PM
  #38
dlyter09's Avatar
dlyter09
Most pulling contests require the vehicles to have a drop hitch to adjust for such things so nobody has an advantage in that category. So say his lifted trucks hitch is 6 inches higher than another truck he may be required to have some sort of drop hitch or a bracket so the heights match up even, and the strap or chain is level
Old Dec 1, 2011 | 12:24 AM
  #39
97tn4x4's Avatar
97tn4x4
I second that, that's the ones I bought.
Old Dec 1, 2011 | 02:22 AM
  #40
yes that is true that most "competition" rules say that but it still proves nothing of your trucks ability, its more so driver "skill" if you will. To prove pulling you have to pull something of equal resistance or weight which ever vehicle can move it or move it the furthest would have the most powered/built vehicle. I think the idea of truck tug o war is cool but it really proves nothing
