Freakin RR bleeder screw stripped!!!!
Replaced all the rusty brake and tranny lines on the truck. 99ram. The driver side rear bleeder screw is stripped. Truck is used and I have never bled the brakes on this truck. Not much room to work on that side. It appears that the bleeder is now between 7 and 8 mm. Kicking my a_ _!!!!!!!!! I used heat and vice grips. Any suggestions!
When I did mine recently, do them in pairs, I relented getting the drum shoes back on. My quick grip was the greatest help ever.
Just get new wheel cylinders and bleeding is a cinch. Just don't damage the nut for the brake line where you are insisted to use a flare wrench.![Wink](https://dodgeforum.com/forum/images/smilies/wink.gif)
PB spray your next lover!!!
