Coolant leak below overflow res?
Old Dec 1, 2011 | 03:15 PM
SteveM4A1's Avatar
SteveM4A1
Default Coolant leak below overflow res?
So I have noticed I have a coolant leak. Each time I fill up the overflow res a couple days later, no more coolant in the reservoir. I've been looking to see if I could locate the leak, and I have found found lots of fluid and gunky stuff located on the hoses below the overflow res. Picture below. Is this normal and should I be looking elsewhere for my leak? I haven't been having any cooling problems, only a slight gurgling sound from my passenger side dash (no wet interior or condensation on windshield) which I am attributing to this coolant leak. Any ideas? Take it to shop?
Old Dec 1, 2011 | 03:43 PM
rwisaacks's Avatar
rwisaacks
If that is the only leak there is, it's probably the reservoir itself. Pop it off and inspect it.
Old Dec 1, 2011 | 05:53 PM
Get rid of the check valve in your trans cooler line too.
